![]() | Home > In Car Electronics > Rear demister / defroster |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
is there not a little clip on the side that you need to pull up with a tiny screwdriver ?
JD1579 Member Since: 30 Nov 2019 Location: Yorkshire Posts: 3 ![]() ![]() ![]() |
Thanks for the reply. I’ve managed to get it off with some force. Slight damage to the connector housing but after giving it a good spray and clean inside (even though i was sure it was too gone to work looking at the condition of it) it has WORKED! All lines seems to be working and de-misting as they should. |
mlambton Member Since: 25 Aug 2014 Location: Axminster Posts: 7 ![]() ![]() ![]() |
I have the common heated rear window connector corrosion problem so took the plug behind the spoiler apart. Its partly disintegrated so would like to replace the 2 pole connector. My question is what rating should the connector be?
Was gonna say 30A |
