Buckster
Hi Dave,
Welcome to the forum, if your XG12 chains are the correct size for your 20s then you will been fine. I would be inclined to do a test fit to check clearance on inside of wheel just to be sure also helps that you can fit them quickly in the cold weather if you do need them 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Thu Nov 28 2019 3:40pm |
