Home > In Car Electronics > Fuel gauge |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
Corroded sender unit connectors inside the fuel tank |
Wed Nov 27 2019 7:45pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
They do have a very common problem, mine did it last year. A joint on one of the in tank sender unit wires deteriorates and it either thinks you have fuel when you don't as happened to me, or it thinks you have no fuel when you in fact do in which case it shuts down to prevent damage to the injection system. You can repair it if you have the inclination, or replace the senders.
Wed Nov 27 2019 7:47pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Google LTB00566v6 might help, or there is a Pdf copy in My Gallery file No. 67.
Wed Nov 27 2019 7:57pm |
1stRangie Member Since: 21 May 2019 Location: Dumfries Posts: 13 |
Wed Nov 27 2019 9:52pm |
