Home > Maintenance & Modifications > Recharging the battery with alarm set.
HughN
Wales
After a week working away I came home to find the battery of my car completely discharged. After using the key to access the car I started to recharge the battery (which was down to 5.1 V). Despite charging at 6 A, it has reached a point where it just has enough juice for the alarm to (briefly) flash the indicators and chirp the sounder, which seems to discharge it again. It isn't possible to disarm the alarm with the remote. I'm assuming that the alarm / immobiliser will prevent jump-starting (which would be tricky given its location).
Any suggestions as to how I might break this empasse?
Thanks,
Hugh
Post #590432 Fri Nov 15 2019 12:20pm
Lindab
May be wrong, but if you have only been away a week & its down to 5v I think you have a dead cell
Post #590439 Fri Nov 15 2019 1:08pm
jimbg
Tend to agree, not sure that one is not coming back! Big Cry 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #590440 Fri Nov 15 2019 1:19pm
knwatkins
Is that your new Bosch one Hugh? Kev
Post #590441 Fri Nov 15 2019 1:27pm
well the obvious thing is to disconnect the battery from the car (one terminal)
and connect the charger directly
Post #590442 Fri Nov 15 2019 1:31pm
HughN
Wales
Duh yeh right obvious. D'oh! Wink
Post #590443 Fri Nov 15 2019 1:50pm
jimbg
Good Luck, I hope it comes back. Thumbs Up 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #590444 Fri Nov 15 2019 1:56pm
HughN
Wales
It has been a very, very long week! I think I used up all intellectual capacity on "hard sums".
Post #590449 Fri Nov 15 2019 2:54pm
aaronjb
Not just one at that point either, probably, at ~2V per cell..
If you have a Ctek or similar, a desulphate cycle might rescue it, if you're really lucky.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #590451 Fri Nov 15 2019 3:02pm
HughN
Wales
It is. Rolling Eyes If it is dead, I do have the receipt.
It does seem to be recovering via the clever charger.
Post #590452 Fri Nov 15 2019 3:02pm
HughN
Wales
All sorted. Thumbs Up
Giving it a desulphate cycle overnight.
Post #590459 Fri Nov 15 2019 5:35pm
knwatkins
Well that's disappointing. I would be tempted to return it anyway, they really don't like being discharged that low so it may have reduced the life of it somewhat. Confused Kev
Post #590469 Fri Nov 15 2019 8:31pm
jimbg
Hugh,
What was the final outcome of your battery saga? Thumbs Up 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #590793 Fri Nov 22 2019 9:43am
HughN
Wales
The final outcomes are:
a) It was fine after a repair cycle by my Ring charger and (touch wood) has been fine since;
b) The evidence of me not spotting the obvious solution was sufficient indication that I need a much-deserved break, so I'm taking one!
Hugh
Post #590965 Mon Nov 25 2019 3:17pm
jimbg
Thumbs Up Thumbs Up Thumbs Up 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #590978 Mon Nov 25 2019 4:39pm
