Home > General (L494) > Park Brake Fault (Smell of burning brakes)
PauloAmore
Scotland
Anything I can do to release the pads until I get to a mechanic?
Thanks in advance
Paulo 2022 P440e AB
Post #590695 Wed Nov 20 2019 5:29pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Take a look on YouTube its on there how to release the EPB did mine a couple of weeks ago very easy.
Post #590696 Wed Nov 20 2019 6:00pm
PauloAmore
Scotland
👍🏾 2022 P440e AB
Post #590699 Wed Nov 20 2019 7:31pm
PauloAmore
Scotland
Can you point me in the right direction of a video please? I can only find precious models and there is no wired loop under the centre console drinks cup holder.
Thanks in advance
Paul 2022 P440e AB
Post #590745 Thu Nov 21 2019 2:30pm
Boxers
If you remove the gear selector just twist it ,& pull it up & off then lever the plastic cover that P R N D are on you will see the hook there put a cable tie through & pull hard it requires a fair bit of pressure.
Post #590750 Thu Nov 21 2019 4:22pm
timhum
Why not call your car assistance company?
Tim Tim
RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame..
Post #590760 Thu Nov 21 2019 7:48pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
If it is an L494 then it has a totally redesigned park brake system from earlier models. The disc pads are driven onto the disk by electric servo motors on each rear disk.
The old system pre L494 has small drums inside the rear discs. The release for these is the small wire loop under the centre consol.
If yours is an L494 then the release is electronic and not manual.(no wire loop under consul)
All I can find for release on the later models is press brake pedal and press down on EPB switch at the same time.
May need a diagnostic tool to release.
If you already have smoke then maybe your system is "stuffed".
Regards Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #590761 Thu Nov 21 2019 7:57pm
Barryp
Just found this in the L494 repair manual, it may help.
With ignition on.
NOTE: This procedure allows the parking brake to be released when removing and installing new rear brake pads or
brake discs.
1. Press and hold the parking brake switch in the release position.
2. Wait 2 seconds.
3. Press and hold the accelerator pedal in the wide open throttle position.
4. Wait 2 seconds.
5. Turn the ignition Off and back On immediately.
NOTE: An audible noise will be heard to confirm that the parking brake has been released in Service Mode.
Regards
Post #590762 Thu Nov 21 2019 8:06pm
