![]() | Home > General (L494) > WATER IN BATTERY TRAY IN BOOT |
Tiger Member Since: 16 Aug 2017 Location: Moscow Posts: 6 ![]() ![]() |
Open the trunk trim on the left and right.
maci234 Member Since: 12 Oct 2014 Location: scotland Posts: 175 ![]() ![]() ![]() |
what do you mean where are pipes located |
can you tell me more about this |
Check behind the rear doorways for these tubes. Left and right in the Luggage compartment.
do i have to remove carpets to see them pipes or where are these exactly thanks |
can you tell me exactly where these are right and left and do i have to remove carpets |
GOT THEM BUT WERE FINE THANK YOU |
Highlighted in red these tubes.
checked them but perfect all in tact and clear not blocked |
And in the compartment under the battery, under the pneumatic compressor there is water? |
yes but where is it coming from ,all sunroof drains are fine and checked , battery tray itself can get full of water , new boot seal ,sealed behind number plate |
any other ideas where this might be coming from |
any idea where else |
