Home > Maintenance & Modifications > MY12 3.0 diesel engine oil |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
I use the Shell Helix AF-L and change it every 6 months with zero consumption and no problems. |
Sat Nov 09 2019 3:31pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
I to use shel helix just changed my second lot and absolutely no issues, never had to top up in a year. |
Sun Nov 10 2019 2:04pm |
Gjlatz Member Since: 01 Mar 2019 Location: UK Posts: 40 |
Hi, Comma oils do the exact Ford Spec. I get it from Amazon the next day.
Tue Nov 12 2019 7:51am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
I haven't used this yet, but this is what will go in next time, most likely: https://www.ebay.co.uk/itm/20L-5w30-C1-Low...1926632098
Tue Nov 12 2019 9:00am |
It meets the spec. That will be absolutely fine. I use the extraction port to remove the oil. Takes about 25 minutes all done |
Tue Nov 12 2019 9:05am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Smith and Allen manufacture the best value C1 oil that meets the Ford WSS-M2C934-B and Land Rover ST JLR.03.5005 specs.
Tue Nov 12 2019 11:53pm |
That's not the case. You can get that grade in 5l and 20l quantities also. I have a 20 litre container I'm using at the moment. You can buy these if you go direct to a distributor.
MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Wed Nov 13 2019 12:08am |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
My personal prefference is the Millers in the right spec used Millers in all my cars for the last 12 years with no issues at all 2012 SDV6 HSE (technically its hers)
Wed Nov 13 2019 10:22am |
I've read on here that Fuchs is the factory fill so that's also available in the right spec. Kev
Wed Nov 13 2019 10:30am |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
maybe its an issue in Ireland. but i didn't get a 20L option from our local distributor i'll have to dig a bit deeper on it. 2007 TDV6 RRS HSE..now gone 2012 3.0 SDV6 RRS HSE |
Fri Nov 15 2019 12:53am |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
Oil has an expiring date. if you buy 20 lt, you,d better use it within 2 years RRS 3.0 SDV6 HSE Lux
Sat Nov 16 2019 10:30pm |
10L per change, who isn't changing their oil every 12 months at least? Usually every six for me, regardless of mileage.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Mon Nov 18 2019 8:07am |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
10 Litres?
Mon Nov 18 2019 9:26am |
Same here. Change the oil every 6 months. Kev
Mon Nov 18 2019 9:56am |
