Home > Maintenance & Modifications > L320 Wheel Arch Edge Protectors
Autobiography1969
Hello All,
As part of the feedback from my recent service (The first one in my ownership)
it was pointed out that I have the complete set of Wheel Arch Edge Protectors
missing, now I have got myself a full set I was hoping they would come with
a clue to where on the arches they fit, I know its a simple push/pull fit but as I
currently don't have any fitted I don't know where they should be located,
Can anyone take a photo of Front and Rear arch trim fitted so I can see..
Thank you very much in advance..
Part numbers
CLB500051 X2 Front Fitting (Longer One)
CLB500061 X2 Rear Fitting (Shorter One) ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #590127 Fri Nov 08 2019 9:49pm
Did have some pictures of these in My Gallery but may have deleted them, will see if I can find them again.
Here is a Front one, do have some better shots somewhere.
Post #590128 Fri Nov 08 2019 9:53pm
Autobiography1969
This is interesting as I think mine had a set of splash guards fitted at some point,
but I think they and the Wheel Arch Protectors were removed..
So they are to protect the painted arch from stone chips from the wheels
throwing stuff up..
Great stuff Col, thank you so far.. ===========================================
Post #590129 Fri Nov 08 2019 10:53pm
Quick shot off rear one, can take better one's later if needed, 28 degrees here so just off to beach. Cool
Post #590130 Fri Nov 08 2019 11:25pm
Autobiography1969
Thanks Col,
So from that I think the orange lines are approximate areas to fit them to..??
Post #590133 Sat Nov 09 2019 12:32am
No rear one's in the wrong place, should be on the wing/quarter panel not the bumper.
Post #590134 Sat Nov 09 2019 12:37am
Autobiography1969
Of course the bumper is plastic so wont rust,,
This better?
Post #590135 Sat Nov 09 2019 12:46am
Post #590136 Sat Nov 09 2019 12:51am
Autobiography1969
Your a real star Col, Bow down
Thank you very much for your time today.. ===========================================
Post #590137 Sat Nov 09 2019 12:54am
No problem, glad to help and doesn't actualy cost anything. Thumbs Up
Post #590138 Sat Nov 09 2019 2:04am
knwatkins
Mine were missing on the rear when I bought the car. When I bought a new pair, I couldn't get them to sit correctly on the arch (parallel with the metal without sagging) so I ended up leaving them off. Let us know how you get on with fitting. Kev
Post #590141 Sat Nov 09 2019 7:52am
Strange, fitted several sets of these and never had a issue, just made sure they were trimmed to exact length required.
Post #590144 Sat Nov 09 2019 8:21am
Brit Plumber
I priced some up for mine a few months back. Not cheap and couldn’t identify the original manufacturer to buy(what I assume to be) an off the shelf roll. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #590150 Sat Nov 09 2019 10:53am
This is what you need, exactly same stuff as the Sport except 20 quid cheaper a set and you get Six pieces instead of Four and cut right will do the whole car twice, as only generally lasts a couple of years or so, although mine have been on nearly Four years now.
https://www.ebay.co.uk/itm/Genuine-Land-Ro...SwFXVZ34L6
Post #590151 Sat Nov 09 2019 11:39am
Autobiography1969
I got mine from our friends at Duckworth-land-rover,,
A little more expensive but genuine JLR products,
https://www.ebay.co.uk/itm/Genuine-Range-R...2749.l2649
So in theory should just need to be pushed/pulled into place,,
I am going to warm them a little in a bucket of water to make
them slightly more supple to manipulate into place..
I will let you know how I get on when I get around to doing it..
Colder/shorter days will get around to it soon..ish ===========================================
Post #590153 Sat Nov 09 2019 12:42pm
