![]() | Home > General (L494) > Mudflaps |
The mudflaps on the 19 are the same as the earlier model,ive fitted a 19 rear bumper on mine with the mudflaps from my15 model.I got mine from here £30 for both sets & they fit good.
Geedubu187 Member Since: 11 Aug 2017 Location: Lancashire Posts: 30 ![]() ![]() |
Thanks for the swift reply, everywhere I looked gave the impression that the later models needed a different mudflap but now I know I will order a set. Quite a saving on 4 pieces of rubber isn't it |
The rear bumper is just about the same except for the middle bit which is inside the red I’ve marked off.The fronts are also easy to fit,they screw to the plastic bit that is at the bottom of the wing,their is one screw underneath it then it just pulls off.
