Home > General > Drivers door mirror 'wandering'
Godders
A couple of months ago I noticed that my drivers side door mirror would end up in the wrong position, particularly after a reversing manoeuvre where the door mirror would adjust as required but not return to the correct position sometimes.
Due to lack of time to investigate I disabled the reversing mirror mode and all was ok until last week. The door mirror has now moved twice when the car has been stopped and parked up. I can only presume the motor maybe shorting or just having a nervous breakdown.
I have searched for any similar issues without success and therefore looking for people with this experience or ideas as to a solution for the problem. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #589387 Mon Oct 28 2019 7:46pm
Brit Plumber
It’s a commonish fault that happens to some but not all. Could be a bad memory motor. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #589453 Tue Oct 29 2019 7:51pm
jordan781
Bulgaria 2006 Range Rover Sport TDV8 HSE Bonatti Grey
Hi, I found the same problem with my car today, I disassembled the entire mechanism, but I found that the two engines located inside do not remember their positions and lose sync. Please tell me how you turned this feature off?
Post #590569 Mon Nov 18 2019 8:38pm
Godders
If you go to the internal settings on the dashboard you can disable the reversing mirrors in there. Thumbs Up Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #590570 Mon Nov 18 2019 8:52pm
jordan781
Thanks Thumbs Up Did you find out what caused this problem?
Post #590572 Mon Nov 18 2019 9:13pm
Godders
I'm going to get a memory motor secondhand and try that but it is a job I will get round to when I have the time. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #590694 Wed Nov 20 2019 6:22pm
