![]() | Home > Maintenance & Modifications > Suspension dropped overnight - front wheels only. |
I'd have a look at your front valve block Hugh. Drop the offside front wheel arch liner and you'll see it. Take it out, disassemble, give it a good clean out and lube up or renew the o-rings. Kev
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
I had the same problem previously |
Ace. I'll dig out the heavy-duty stands. I don't want a heavy car dropping on me - again. |
I thought I'd bite the bullet and change the valve-block. The car had a new pump before I bought it and I couldn't help wondering whether there were bits of desiccant in it. Bumper-off, cracked the joints and walked away ... swapped it over and bumper back on. So far, so good: it hasn't dropped and the pump runs for less than ten seconds when I start the car after 24 hrs - better than the minute or so before the valve-block was changed, and much better than the four minutes it took with a leaky reservoir.
Glad you got it sorted Hugh |
