Home > In Car Electronics > Analogue TV to digital ?
stuartmc83
United Kingdom 2005 Range Rover Sport TDV6 Santorini Black
Hi I’ve had a look and it seems there’s loads of different units! Can anyone point me in the right direction of how to make my tv work ? It’s got an analogue tuner just now so doesn’t work
Post #589263 Sat Oct 26 2019 7:37am
Brit Plumber
Can you get a photo of the connections you have. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #589270 Sat Oct 26 2019 9:59am
stuartmc83
Hi I can get one, I’m not sure where they are though to photograph lol. Can you help by telling me where they’re located ?
Post #589274 Sat Oct 26 2019 1:01pm
Brit Plumber
What year and model? 2019 5.0 SC SVA (Current)
Post #589278 Sat Oct 26 2019 1:13pm
stuartmc83
It’s a 2005 Range Rover sport 2.7diesel
Post #589279 Sat Oct 26 2019 1:14pm
geoffsnook
Should be in the boot on the right but if its a 2005 it may be analouge Thumbs Up
Post #589324 Sun Oct 27 2019 9:27am
stuartmc83
Hi it is analogue I need to find out what I need to upgrade. On the right in the boot is the DVD interchanger can’t see the TV stuff??
Post #589334 Sun Oct 27 2019 11:56am
geoffsnook
If you have a factory fit unit it should be in there search this site and disco3 for pictures of where it should be if its not there you may not have the factory fit but maybe aftermarket Thumbs Up
Post #589337 Sun Oct 27 2019 2:19pm
stuartmc83
I’ll need to have a good look when it’s not so cold outside but I’m pretty sure it’s factory fitted
Post #589342 Sun Oct 27 2019 4:39pm
Brit Plumber
It’s in a bracket on the right side of the boot behind the radio receiver (I think). 2019 5.0 SC SVA (Current)
Post #589357 Sun Oct 27 2019 9:17pm
Brit Plumber
There’s only one digital unit listed, pt number 7H4219C063AB used on VIN 9A201355 on however I suspect it can be retro fitted to earlier vehicles but it may need other parts such as wiring and window amp.
A check on eBay shows non available however the 7H4219C063AA version from the L322 is so this may work. 2019 5.0 SC SVA (Current)
Post #589358 Sun Oct 27 2019 9:38pm
geoffsnook
There's a lot on Disco 3 about upgrading also so try over there quite a few have done it Thumbs Up
Post #589363 Mon Oct 28 2019 7:17am
