Home > Technical > 2011 RRS Dead! |
WinterRover Member Since: 24 Oct 2019 Location: Templeton, CA Posts: 4 |
Just joined this forum looking for some help! Sorry for the long post.
Thu Oct 24 2019 2:40pm |
Are you talking 5.0 SC or NA?
Thu Oct 24 2019 5:40pm |
Thank you for the responses.
Thu Oct 24 2019 8:33pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4996 |
Probably the long cranking that damaged it
Thu Oct 24 2019 8:37pm |
I was wondering if coolant may have caused the solenoid to have seized in the engaged position and therefor causing it to continue cranking. 2019 5.0 SC SVA (Current)
Sat Oct 26 2019 9:55am |
I had the wife try to start it while I was underneath with a volt meter and I was getting 11.9v to the starter through the solenoid. Got nothing from the starter. Took the starter out and hooked it directly to 12v and still got nothing. I'm ordering another starter motor and in the mean time I will be replacing all the coolant parts that I ordered to fix (hopefully) the original problem. |
Sat Oct 26 2019 11:14pm |
While waiting for the starter to arrive, we went ahead and replaced all the coolant stuff I ordered. Replaced the rear crossover pipe, the front crossover pipe and the water pump. Found the leak!!!! Both tubes that fit into the block on the front crossover pipe were broken. When we remove the intake you could see the coolant residue and when the pipe was removed, we had to dig out the O-rings and pieces of both tubes! Total hard failure. I can't believe how many different coolant routes are on this thing. Failures waiting everywhere?
Wed Oct 30 2019 1:58pm |
