![]() | Home > General (L494) > Do current RRS still have oil dilution problem ? |
Estrace Member Since: 24 Sep 2019 Location: AIGUES VIVES 30670 Posts: 15 ![]() ![]() |
Fabio I have a RRS SDV6 bought new in May 2019 I followed the service indicator and it requested an oil change at 21500 km in end February 2020, mostly in line with the standard JLR scheduled oil change of 24000 km I used mostly standard diesel fuel and used « super » diesel fuel only once every 5 tank full It used the original oil from JLR and I added a total of 1 liter of the same oil in 20000 km and of course I reused the recommended oil and filter to change the oil Following the concerns about fuel dilution in the oil on this forum and other specializes literature as well as JLR recommendations on the subject, I took a sample of the old oil and I had a specialized company perform a complete oil analysis The result was clear, absolutely no oil dilution, 0% fuel in the old oil For info the car was used 90% of the time on motorways at maximum speed limit, 8% on small roads, 1% off road and 1% in city, including 3000 km towing a 3,5 tonnes trailer mostly on motorways In conclusion if you have a similar type of use, you do not need to order a gasoline RRS and you can order a 2020 diesel model without bothering about problems of fuel dilution in the oil Apparently the problem of dilution is mostly with city driving and frequent very short trips and seems less frequent with the latest models I hope this helps you take a decision Cheers Serge |
fabiofranchi Member Since: 23 Apr 2016 Location: Firenze Posts: 17 ![]() ![]() |
Hi Estrace,
