![]() | Home > Technical > Coffee machine |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Depends on how big the inverter is supplying the socket |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
i suppose its beats making coffee in a saucepan over an open fire... |
Risky doing that in the boot. |
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 ![]() ![]() |
Near the plug socket it should state how much power ( Watts) can be supplied and used. Check the power usage of the coffee machine and if its less then no problem. I would advise not to go to equal or more Wattage as this could cause problems and obviously invalidate warranty if you go for more Wattage and damage occurs. ![]() |
01BENN Member Since: 29 Apr 2019 Location: Sydney Posts: 4 ![]() ![]() |
Thanks for the advice guys. I’ll let you know how I get on |
