![]() | Home > Maintenance & Modifications > Adaptive Headlight warning light and bulb out |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
you need a new bulb regardless so i would start there...... |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
I don’t think you have bulb fail warnings on these.
dukeminster Member Since: 26 Apr 2013 Location: United Kingdom Posts: 29 ![]() ![]() ![]() |
so i changed the bulb and it is working but the adaptive headlight warning light is still on the dash....whats next? |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 474 ![]() ![]() |
Firstly get the codes read and cleared,
thanks, i'll see what i can do codes wise...i have one of those bluetooth OBD2 devices i might try that on it.
was it the same bulb/lamp as the passenger side? ===========================================
yes both were the main xenon dipped beam bulb |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
The xenon does both dipped and main - there's a shutter that moves to give the necessary light output. The halogen comes on as a main beam pattern filler to ensure even light spread when main beam is selected. 2012 SDV6 - it's missing a couple of cylinders
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I've had problems with my AFS headlights ever since I bought my RRS. As it wasn't covered by my warranty and was an intermittent fault, I've put up with it. I don't do much driving at night and so it was not a major inconvenience. Biggest issue is if it playing up when the MOT is due as it could be a fail.
