Home > Maintenance & Modifications > Shuddering at low speeds - it's back... |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
This sounds to me like the dreaded torque converter problem. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Oct 05 2019 12:25pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Agreed |
Sat Oct 05 2019 12:39pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
Ho, hum. Oh well, after a bit of Googling, at least I now know what a lock-up clutch is.
Sat Oct 05 2019 2:55pm |
A new TC is probably all that's needed if the problem is relatively recent.
Sat Oct 05 2019 5:11pm |
Cheers, Wayne. I will go down that route. |
Sat Oct 05 2019 6:10pm |
Is this likely to be a body-off job? From what I've found on the internet (which, as we all know, is always correct), it seems to be possible without, but only by masochists and/or Mr Tickle. |
Mon Oct 07 2019 3:38pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 |
Don't think so. |
Fri Oct 11 2019 11:00am |
LYONS1 Member Since: 12 Jun 2019 Location: cape town Posts: 10 |
Just add a tube of Dr Tranny Shudder fix to your gearbox oil, sure the problem will be fixed. That stuff works like a charm, it already fixed my fluctuating ref-counter issue. |
Fri Oct 11 2019 1:23pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
+1 on the Dr tranny. My X5 had the shudder 5yrs ago so I did a trans service and put in some Dr Tranny (is that a PC name these days..) and its been fine ever since. |
Sat Oct 12 2019 1:53pm |
Dr Tranny will help but the issue is caused by contamination of the torque converter clutch surfaces, so it's not a "fix" merely a cover of the symptoms.
Mon Oct 14 2019 8:48am |
Slightly in trepidation at what a search for "Dr Tranny" might return, I was surprised at how overwhelmingly positive the reviews are. However, I can't understand how it helps the LUC problem so I can't believe it either. What I don't want to happen is lots of dwarf or assorted crud to find its way to the valve-block.
Mon Oct 14 2019 7:36pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Here:-
Tue Oct 15 2019 7:27am |
How much of a pain is it to put it in the gearbox? There are effectively only two weeks between now and it being fixed and most of that is in the same gear on a motorway. |
Tue Oct 15 2019 7:36am |
From memory of other threads, jack the vehicle up on the side what has the gearbox fill point (so that the oil doesn't run out) squeeze in the lube additive.
Tue Oct 15 2019 10:46am |
