![]() | Home > General (L494) > Confusing Spec Speak - Help Please? |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 ![]() |
I may be wrong but I think you’ll find the lane change doesn’t require the mirrors....it uses the front camera to determine the lane change without the indicators being used...I had it on my last 494 and it’s useless and you’ll never use it...all it does is shake the steering wheel if the car veers across lanes if you haven’t indicated.. |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
Sorry i dont mean the one that shakes the steering wheel, it has that aswell, the spec says lane merge aid which I assume is when you want to change lanes and it beeps to tell you something is coming from the rear, blind spot monitoring really.
Or maybe you’re right and that explains it, Ive not got the spec sheet to hand to see if it said something else for the one that shakes the wheel |
Blind spot alert,the mirrors will have 2 little squares in bottom corner,one is red to let you know the vehicle overtaking you is close so don't pull out,its also good when reversing out of blind spots as it lets you know if their is anything coming across the rear of you,i had it on my SC & it works well. Andy.
Yeah I have the blind spot monitoring, reverse traffic detection and the lane change assist that shakes the steering wheel on my L405 5.0 SC but havent seen this SVR as yet. The spec list from LR says it has lane departure warning system which I assume is the one that shakes the steering wheel, it has lane change merge aid but not proximity mirrors.
