Home > Maintenance & Modifications > Wheel swap |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 908 |
Andy, have you tried ACF 50 corrosion block. Easy spray on. Loads of bikers use it. Google it
Fri Oct 11 2019 5:56pm |
Just had a read up on that Lindab thanks,now it’s where to find best place to buy a gallon.Ideal if you buy a new car & do the underside every 12 month. Andy.
Fri Oct 11 2019 6:12pm |
Andy, 4 litre for £79.90 with free delivery on Ebay. They are open to offers so you will get it a bit cheaper |
Fri Oct 11 2019 9:54pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Good idea re. the Poorboys on the caliper Andy. I think I'll have to do that myself.
Sat Oct 12 2019 10:49am |
Ive got C5 on my wheels but I put 3 coats of poorboys on the calipers as I cannot leave to cure over night & the temp in my workshop is probably too cold that's the reason I chose PB.The C5 on the wheels is holding up well & still a breeze to clean,but saying that I never let them get too bad before I clean them & its never left more than 2 weeks between cleaning the car & wheels. Andy.
Sat Oct 12 2019 11:04am |
Thanks Andy. I also have the C5 on mine but I may give the Poorboys a go next time to compare. Kev
Sat Oct 12 2019 11:09am |
The difference is C5 will last about 2-3 years were as PB needs doing about every 6 month but it’s easier to remove one wheel at a time apply 3 coats then re-fit in any weather. Andy.
Sat Oct 12 2019 4:37pm |
