![]() | Home > Maintenance & Modifications > Rear dynamic response (ACE) bar replacement costs |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Budget around £13-1400, including fitting and replacing rear pipework |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
You can buy the bar OEM which is about half the price of the same bar with LR stickers on it from an LR dealership. That helps get you to D_M's figure. LR charge £1300 or so just for the bar if you go to them...!
Bruster400 Member Since: 12 Jun 2019 Location: Manchester Posts: 15 ![]() ![]() ![]() |
Thanks guys!! |
hmmmmm another quick question if you don't mind......
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
I know it's a bit of a trek from Manchester but for a Land Rover independent specialist try K Motors in Leyland. I've had pretty good service from them for a while now & their labour rates are about half the main dealers.
Just to update: Had this done last week for £1220 all in. Not the sort of bill you expect at <50k miles but it's a hell of a lot better than the other quotes I got!! Very happy with the garage - found through this forum too! For info: 6hrs labour for this job and they said they were able to do it without lifting the body which I'd been told couldn't be done....
Rear pipes too, or only the bar? |
Sorry Disco_Mikey - I missed your question.
