Home > Technical > NO TV
maci234
NO TV
HAS ANYONE RETROFITTED TV IN THERE L494 RRS AUTOBIOGRAPHY DYNAMIC 2013/14
Post #588212 Mon Oct 07 2019 12:56pm
Brit Plumber
It shouldn’t be to hard from a wiring point of view. It links into the infotainment so some rejigging of MOST, biggest thing is probably the CCF edit if you don’t have SDD or an IID. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #588218 Mon Oct 07 2019 2:00pm
maci234
maybe most wiring is there required if required alot of things can be plug and play without coding need some experts
Post #588228 Mon Oct 07 2019 4:10pm
Brit Plumber
Unless LR have changed the way they market their products, the L494 won’t have any wiring for the TV. They haven’t provided the wiring in any model thus far that hasnt had it installed at the factory. The MOST definitely won’t be there as it requires a loop to bypass the module if not installed and LR wouldnt want the added expense or want the trouble of an extra risk of a fibre optic being damaged.
As for plug and play, definitely not, there are a number of CCF edits required to turn the option on in the FCDIM. 2019 5.0 SC SVA (Current)
Post #588241 Mon Oct 07 2019 7:49pm
maci234
do you know of anyone that may have done it ,maybe aftermarket options ,
Post #588251 Mon Oct 07 2019 9:38pm
Brit Plumber
I don’t know of anyone who’s done it, probably due to it being crap! I have it in mine as factory fitted and it’s only any good when parked for a few minutes. On the move it loses signal and if parked with the engine off it shuts down in 5 minutes. Aftermarket probably isn’t much better. 2019 5.0 SC SVA (Current)
Post #588252 Mon Oct 07 2019 9:54pm
maci234
do you know what parts i would need quiet a few things as yourself has done a few things
Post #595567 Tue Feb 25 2020 3:20pm
