![]() | Home > Technical > The annoying "Restricted Performance" |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 ![]() ![]() ![]() |
Start with having a look for any codes that might appear. I had this happen during the summer and took 5 trips to the dealer to remedy a cross over pipe issue.
Darren Anthony Member Since: 08 Mar 2019 Location: Birmingham Posts: 30 ![]() ![]() ![]() |
Yeah. I did a search first and there seemed to be numerous different things being done by people to try to remedy the error.
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
How much they charged you and was it a body off repair? RRS 3.0 SDV6 HSE Lux RRS 3.0 TDV6 gone LR 3 HSE V8 gone DiscoveryII V8 Gone Discovery 1 V8 Gone Mustang Shelby Alfa Guilia (classic) |
Thankfully it was under warranty and replaced a melted fuel line at the same time, body on. 2018 Telsa MS
New reader arrived today.
Thinking about it, I'm guessing it's not going to be the MAF sensors, a if one of those was faulty, the warning would be on all the time.
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 ![]() ![]() ![]() |
The intake pipes are the most likely in my opinion, this was a very common fault over on the FFRR forum. My 4.4 TDV8 had two of the four inlet pipes split when i was getting the restricted performance. The manifold doesn't show all the time as when the engine is just steadily moving around town it's not under much pressure. As soon as you get on the main roads and load it up it starts sucking and opening up the splits.
After driving it today, this actually sounds very likely.
Slightly late follow up to this.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 920 ![]() ![]() |
Its good to see you posting up the final fix. So many times people ask for help and get various replies but never come back to say how the problem was solved. |
Ditto above!! Glad to hear you are all sorted.. |
bmszabo Member Since: 10 Aug 2019 Location: Tilburg Posts: 61 ![]() ![]() ![]() |
Had exactly the same - but with my LR Discovery. Pretty expansive reparation. |
