Home > Technical > Parking aid wierdness
RRS Shaun
Hi all,
Had a search on the forums but cannot find anyone with the same issue.
From the beginning:
Had issue with rear parking sensors not working, would beep and flash when put in reverse. Identified two sensors not working and replaced, all good.
A few weeks later issues again, replace other two sensors and works however seem to have to get really close before beeping.
Before I get to investigate, about a week later, we loose front parking aid and so no sensors working at all, long beep and flashing button once car is started, message saying front park assist disabled (or somthing like that).
Found that one of the front sensors has now failed and not clicking.
This week, the whole system has given up, no messages, and as soon as key is turned to position 2 (before engine started) i get a long beep with flashing button.
Any ideas on this? Could it be the module itself has now had enough? Fuse is fine.
Post #588154 Sun Oct 06 2019 2:02pm
Brit Plumber
Genuine sensors fitted or eBay specials? Lots of issues with non genuine items. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #588176 Sun Oct 06 2019 8:50pm
RRS Shaun
Yeah, got them off eBay however are still valeo units the same as originals.
Post #588247 Mon Oct 07 2019 8:52pm
