Home > General > 2012 sport no power on passenger side
Page 5 of 5 <12345
Brit Plumber
Yes the mirrors won’t fold until the car is all locked. If you say the locks have been replaced, they may just need setting up. If the section on locks isn’t in the emails I sent you it must be in the 3rd file which was to big to send. I’ll see if I can just post the section you need. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587966 Thu Oct 03 2019 5:41pm
Steven 17
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Fuji White
I’ve done that much reading about this car I’ve lost my marbles over it the past few days ha ha.i thought the locks are just plug and play thow?i have to physically lock both doors by hand but once I lock the rest of the car I can walk to the passenger door reach for the handle with key in my pocket and I can gain entry but the interior lock switch still stays locked so must have some sort of power to the lock
Post #587971 Thu Oct 03 2019 6:42pm
Brit Plumber
Have a look at this thread on the sister site. There’s a comment on how the new lock has a tab preventing the door locking....interesting....
https://www.disco3.co.uk/forum/replacing-d...=door+lock 2019 5.0 SC SVA (Current)
Post #587976 Thu Oct 03 2019 7:09pm
Steven 17
Been messing on the car agin this morning and I’ve swapped out the new lock on passenger front with the one off my 10 plate sport and still getting the exact same problem.ive put the new lock in the 10 plate sport and that works perfect.so it is 100% not the lock mechanism.ive plugged the computer back in and getting one fault saying mirror short circuit or open.it let me erase the code but would come back again.so I’ve swapped mirror off the 10 plate sport too.now no faults at all but still no locks.i was hoping it was the mirror causing it but I was wrong.ill put a pic up of the mirror code but it can’t be that now as I’ve changed the mirror and not getting that fault any longer.so it’s like there’s no power going to the locks
Post #588012 Fri Oct 04 2019 11:26am
Brit Plumber
That code and I have a love hate relationship!
Post #588014 Fri Oct 04 2019 12:15pm
Steven 17
I’ve no idea if it’s the motor in the mirror or damaged wires but I plugged a different mirror in and that fault went.i wish these locks was that simple
Post #588019 Fri Oct 04 2019 2:14pm
Brit Plumber
With mine I suspect it’s the earth wire in the mirror loom. It happened after I replaced the glass, car would lock but mirror wouldn’t fold. Pulled both wing mirror glass out and changed the 2 connectors over on the passenger side and it all worked but get that DTC.
If you press the key fob lock button twice does it make any difference to pressing it once? 2019 5.0 SC SVA (Current)
Post #588020 Fri Oct 04 2019 2:50pm
Steven 17
No mate double pressing the lock button makes no difference at all
Post #588084 Sat Oct 05 2019 1:32pm
Page 5 of 5 <12345
