![]() | Home > In Car Electronics > Dual remote lens dashcam system writeup with pictures... |
I’ve been wanting a dashcam for a long time because these days with fraudulent insurance claims and ‘crash for cash’ scams, having some video evidence could prove invaluable. However, I’ve been held back because I’m a bit OCD about the inside of my car – the door bins are always empty, drinks bottles/cups are never left in the cup holders and I would not be able to cope with anything significant stuck to the windscreen.
Compared with my key this shows how tiny the cameras are…
Now onto the install in the RRS: I wired straight into the internal fusebox with the hardwire kit provided. I used fuse 29 for the permanent live and fuse 54 for the ignition live. The little box on the left is the power controller that will shut the system down if the battery level drops to a particular voltage. This is configurable between 11.8V to 12.4V.
Earthed using one of the earth points behind the passenger kick panel…
The front camera is mounted behind the rear view mirror so I cut a little slot in the housing to hide the cable…
I wanted to hide the GPS receiver and it worked out that the base of the A-pillar was the most convenient place for this. The GPS receiver also contains the microphone to record the audio….
In order to minimise any rattles, I wrapped all of the cables with automotive fabric tape…
And ran them from the top glovebox...
For the rear camera, I ran the cable under the sill covers…
I also removed the internal rear quarter panel to run the cable along the existing loom. I also took the opportunity to tidy up the rats nest that someone created whilst fitting aftermarket towing electrics…
And here is the end result. Front camera…
Rear camera…
Control unit in the top glovebox… ![]() There is also a little wireless remote control that can be used to snap still images when pressed. I mounted that on the side of the steering column…
Footage can be viewed either by opening the videos files directly or using an application called RCam. This is pretty cool as it simultaneously displays the front and rear cameras along with a moving Google Maps showing your GPS location. It also gives you a speed and G-sensor readout…
I’ll get some footage uploaded over the next few days for your viewing pleasure. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 248 ![]() ![]() |
Very tidy and impressive solution! |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
I expected the price to be much, much higher .. that's a really nice bit of kit for the cost, so I'll be interested to see the video output |
Nice install. Please post price In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112 ![]() ![]() ![]() |
From the links & description above I presume it's this... http://www.combi.org.uk/products/194/K2S-D...R-2x-1080P 2008 TDV8 Buckingham Blue- SOLD |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Out of interest , Why choose this over the Mini 0906 dual cam ?
Hi Luke, I went for this because it's a lot more discrete than the 0906. Yes, the 0906 is small, but not as small as the just the camera on its own. Having the electronics separate and being able to hide it away was the big plus point for me. Kev
