![]() | Home > Technical > Rear brake plate/splash guard replacement |
They are bolted on but they are usually rusted so you need new screws/bolts. Now the bad bit, you need to split the bearing so you need to fit new bearings too. If you’re not in a rush, keep an eye on ebay as genuine parts can sometimes be available quite cheap. I picked up a New genuine LR rear bearing for £8 back in April and I’ll be fitting that when I do my rear brake splash shield. 2019 5.0 SC SVA (Current)
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
just replaced mine, big job replacing bearings, epb shoes, abs sensor, and some bushes.
That's because the split shields are an Atlantic British custom designed and manufactured part |
Fictivision Member Since: 31 Oct 2015 Location: Molde Posts: 31 ![]() ![]() ![]() |
Oh my,so much for an easy job |
get normal ones and cut them where Atlantic British have.
Great,thanks for the tip. Will see what I can do. |
