Home > General > 2008 TDV8 BOTH TURBOS GÒNE RUN WITH 60 LITRES PETROL ALLEGE
Page 2 of 3 <123>
Tobias75
England 2008 Range Rover Sport TDV8 Autobiography Zermatt Silver
Sorry for the late response and thank you for all your comments and assistance, i have finally found time to get back to the jeep.
I have taken off both lower intercooler pipes and covered myself and driveway with oil. And guess both turbos are fooked !
Is it possible to raise the suspension without it running as its extremely tight on space as the air bags are on the floor.
Before I go and buy a second hand engine I think it's only right to try and get it to run without the turbos which I understand it should.
Can anyone link me to a video or advise how to do a leak off test on the Injectors and the correct way to do a compression test.
Just to clarify my pal said it was measuring well over 3 bar at the rail whilst cranking.
Thanks in advance
Post #587566 Wed Sep 25 2019 9:02pm
Tobias75
@discomikey it was indeed a copart purchase, do you know the jeep ?
Post #587568 Wed Sep 25 2019 9:07pm
Disco_Mikey
Very possibly. Copart picked up one from a customer of mine. LH turbo seized, sucked oil into the engine and hydraulic locked the engine while running, suspect there is a bent rod or 2...
There would also have been absolutely no fuel in it, a poorly battery, a faulty BT module, and a head unit stuck in phone mode, if it was the same car
If it does turn out you néed an engine, I have one here for sale Thumbs Up
Post #587573 Wed Sep 25 2019 9:39pm
Tobias75
There was fuel a flat battery dont kow what a BT unit is and the stereo works ok maps ect.
It came from uckfield garage 3 bell lane via liverpool Victoria insurers.
Can someone link me to how to access and perform
1. compression test
2. leak of test
Regards
Post #587574 Wed Sep 25 2019 10:00pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
Why do you bother when not knowing basics? unlikely to be fixable from your laptop Mr. Green
BTW: this is a RRS forum - jeep might have their own
and I'm off Embarassed Embarassed
Post #587575 Wed Sep 25 2019 10:13pm
Tobias75
Thanks for that I think🤔
I know how to compression test just never worked on a range rover before hence asking for some basic guidance on how easy it is to access and basic pointers.
Same with leak off, I've never accessed the injectors before so was wondering were would be best to start accessing them ect.
I'm no specialist but pointed in the right direction with the right information is within my capacity
Post #587576 Wed Sep 25 2019 10:26pm
rover75
It wasn't meant in a bad way, but now you've mentioned another word than jeep.
Here's WM kindly offered by someone I stole link from: https://www.mediafire.com/folder/bmioajx5v76k7/RR
Post #587578 Wed Sep 25 2019 10:43pm
Tobias75
Thanks rover75, appreciated. No offence by jeep reference btw, all 4x4 are jeeps in my eyes.
Post #587606 Thu Sep 26 2019 11:26am
Brit Plumber
😱 no, no, no, not all are jeeps....
This is a Jeep, 77 years old and on its second engine......and not due to a snapped crank or seized turbos or warped head. It was a crack in the water jacket.
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587653 Fri Sep 27 2019 8:43am
Lindab
Ridiculous, only 77 years old & on its second engine already Rolling with laughter Bow down
Post #587656 Fri Sep 27 2019 11:28am
SteveNorman
The quickest way to check relative compression is find someone with a picoscope you can borrow or ideally get them to come out to the car.
Charge the battery, then Pico has a relative compression function on picodiagnostics.
Disconnect all injector plugs, then crank the engine & it should show what each cylinder compression is like.
It's only relative to each other & you can't tell which cylinders are which (without further tests) but is a very quick test to tell if the engine is worth spending any more time on.
regards
Steve
Post #587719 Sat Sep 28 2019 2:59pm
Tobias75
Today I went to perform a spill test on injectors 1-4 and the leak of pipes spurred out diesel just by turning the ignition on.
Decided that there must be a faulty inject on bank 2 so removed all injectors, injector 5 was bone dry and 8 was more carboned and wetter than the others.
Injectors getting tested monday, my pal said he's confident that compression is fine due to the way it sounded when it tried to run and is going to bring his computer to do a compression test electronically when the injectors are put back in.
N/s turbo has definitely failed, on a plus side I found the service pack book today and it has full service history so fingers crossed it's just injectors and turbos that need replacing.
Wheres the cheapest place to get turbos and what labour charge should I be looking at to fit ?
Post #587733 Sat Sep 28 2019 8:25pm
Disco_Mikey
Cheapest option will likely be far from best option...
Post #587736 Sat Sep 28 2019 9:12pm
Tobias75
So where would you get 2 new turbos from?
Post #587738 Sat Sep 28 2019 9:41pm
Disco_Mikey
Brand new OEM turbos is all we fit Thumbs Up
Post #587751 Sun Sep 29 2019 9:30am
Page 2 of 3 <123>
