![]() | Home > General > Battery Charger/ Solar battery maintainer? |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
I should really count how many Ctek's I have sitting around here .. there seems to be a ready market of RRS owners for them |
i've found a 4 or 5A CTEK works fine on the RRS, but that is for maintenance and when working on it. |
What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112 ![]() ![]() ![]() |
CTEK Stage 1 mode: desulphation; would that not address the hardening/baking?* *I literally opened the user manual, that is my level of expertise...and yes I already used the 5A to do battery recon which is working so far ![]() |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Good question, and although I have 3 Ctek's, 2 x 5A (used in 0.8A mode for motorbike & kids buggy etc. at 7 / 9Ah) and a 10A for RRS, tractors etc. I've never thought of it. So some quick googling brings up the below (from - https://batteryuniversity.com/learn/articl...event_it); "There are two types of sulfation: reversible (or soft sulfation), and permanent (or hard sulfation). If a battery is serviced early, reversible sulfation can often be corrected by applying an overcharge to an already fully charged battery in the form of a regulated current of about 200mA. The battery terminal voltage is allowed to rise to between 2.50 and 2.66V/cell (15 and 16V on a 12V mono block) for about 24 hours. Increasing the battery temperature to 50–60°C (122–140°F) during the corrective service further helps in dissolving the crystals. Permanent sulfation sets in when the battery has been in a low state-of-charge for weeks or months. At this stage, no form of restoration seems possible; however, the recovery yield is not fully understood. To everyone’s amazement, new lead acid batteries can often be fully restored after dwelling in a low-voltage condition for many weeks. Other factors may play a role. A subtle indication whether lead acid can be recovered or not is visible on the voltage discharge curve. If a fully charged battery retains a stable voltage profile on discharge, chances of reactivation are better than if the voltage drops rapidly with load. Several companies offer anti-sulfation devices that apply pulses to the battery terminals to prevent and reverse sulfation. Such technologies will lower the sulfation on a healthy battery, but they cannot effectively reverse the condition once present. It’s a “one size fits all” approach and the method is unscientific. Applying random pulses or blindly inducing an overcharge can harm the battery by promoting grid corrosion. There are no simple methods to measure sulfation, nor are commercial chargers available that apply a calculated overcharge to dissolve the crystals. As with medicine, the most effective remedy is to apply a corrective service for the time needed and not longer. While anti-sulfation devices can reverse the condition, some battery manufacturers do not recommend the treatment as it tends to create soft shorts that may increase self-discharge. Furthermore, the pulses contain ripple voltage that causes some heating of the battery. Battery manufacturers specify the allowable ripple when charging lead acid batteries." So it looks like this mode isn't recommended by all battery manufacturers, and it's they who I'd be taking the best advice from. I'll just keep aiming for around 10% Ah rating. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
Sorry not really about solar chargers but-
