Home > Technical > warning lights
ratty2828
England 2007 Range Rover Sport TDV8 HSE Java Black
warning lights
Bit of help needed here,driving along today,suddenly a few warning lights came on as follows Suspension light ,,DSC Light Adaptive Front Lighting System,,,ABS Light,,Brake System Light All are Amber Can anyone help me please all stay illuminated
Post #587562 Wed Sep 25 2019 8:19pm
Brit Plumber
You need the codes reading for an accurate diagnosis. They are all related to suspension, even the adaptive lights and DSC as the system uses suspension data. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587565 Wed Sep 25 2019 8:44pm
ratty2828
warning lights
Brit Plumber
Thanks for that advice,i am taking car to LR guy today,off the top of your head any idea what could be the problem
Post #587583 Thu Sep 26 2019 5:35am
Brit Plumber
These warnings are quite common to a few problems, instrument cluster - can get erroneous indicator flashes and many other can bus problems, water in the glovebox fusebox is another.
Check under the passenger carpet for damp, drop the glove box and check for dampness on wiring and fusebox.
When you get the warnings, try hitting the top of the dash above the instrument cluster. 2019 5.0 SC SVA (Current)
Post #587599 Thu Sep 26 2019 9:44am
ratty2828
warning lights
Thanks Again Brit Plumber took car into garage mechanic says its the rear wheel speed sensor coming up as faulty
Thanks
Post #587615 Thu Sep 26 2019 12:27pm
Brit Plumber
Yep that will probably do it as that has an input to suspension (access to normal at 5mph, lowering suspension by ?? mm at 100mph etc), ABS is obvious, DSC is in with the suspension etc. Etc
Just be aware that these things have a habit of escalating, but it can’t be to expensive to replace. 2019 5.0 SC SVA (Current)
Post #587616 Thu Sep 26 2019 1:33pm
ratty2828
warning light
Bit Plumber,,, unit cost £140 from Land Rover Dealer plus what mechanic takes to fit so not to bad
Thanks for your input
Post #587632 Thu Sep 26 2019 5:41pm
Brit Plumber
That’s a bit more than I expected but it could have been much worse. 2019 5.0 SC SVA (Current)
Post #587634 Thu Sep 26 2019 6:20pm
