![]() | Home > Technical > advice please on updating maps on 2019 rrs |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
If you a talking about a 2019 car ( not 2013 or 2015! ) then the app is downloaded from the web page.
pko Member Since: 31 Jul 2011 Location: norfolk Posts: 193 ![]() ![]() ![]() |
Hi jimbg. thanks for response. I've tried again today and all is working correctly as it did last time I updated.
Glad it is working now. |
jd2uk Member Since: 01 Apr 2017 Location: Kent Posts: 109 ![]() ![]() |
Is anyone able to provide any guidance on USB memory sticks that are recognised by the vehicle? I've downloaded the maps successfully onto a variety of USB memory sticks but they never seem to be recognised by the car unless I'm doing something wrong (although I am following the instructions shown on the website) |
Where are you plugging it in? 2023 P440e SE Dynamic on order -cancelled
The USB ports in the centre console? Don’t tell me it’s the wrong place |
Have you tried both? 2023 P440e SE Dynamic on order -cancelled
Yes. If you have done it successfully can you please advise what memory stick you used? |
I am using a 32Gb Sandisk Cruzer. 2023 P440e SE Dynamic on order -cancelled
Interesting... I'm using a 64GB SanDisk Cruzer. Did you format it using any specific file system? |
I just did a quick format, maybe try a 32GB stick? 2023 P440e SE Dynamic on order -cancelled
Just tried a quick format in exFAT format but no difference. Could try NTFS but not sure that would work?
Can you play music from the USB slot? Just wondering if you have a hardware fault. 2023 P440e SE Dynamic on order -cancelled
Apple CarPlay works? |
