Home > Tips & Tricks > Memory function
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Memory function
Just noticed today that with the diffrent keyfobs when activating the lazy entry it also will change the display mode from miles to km depending what was last set when you used the car last. My key was used with km/h and the SWMBO last used the car in the UK and was using mph. When she took us all out for a drive today the dash / sat nav reverted back to mph and miles per gallon. She then locked the car and I opened it with my key and it came back up in km/h and l/100km.
Intresting and not documented in the handbook. Sons of dogs come hither and get flesh
Clan Cameron
Post #146725 Wed Nov 28 2007 7:48pm
Didn't know that either - good spot! Thumbs Up
Post #146755 Thu Nov 29 2007 11:14am
Socketuser
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Baltic Blue
How do you turn off lazy entry.
RRS 62 plate
Post #587033 Mon Sep 16 2019 5:08am
You can't because it doesn't have it on a 62 plate car, it went out in 2009 with the pre facelift cars. It's now called Entry & Exit mode controlled by rotary switch on steering column just turn to off position.
Post #587034 Mon Sep 16 2019 5:18am
Preston-rr
United Kingdom 2010 Range Rover Sport SDV6 HSE Sumatra Black
what is entry and exit mode? how do I set it, what does it do? Novice here has no idea? 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #605344 Thu Oct 08 2020 11:18am
Small rotary "Knob" on steering column below Wiper/Washer stalk on a RRS2 I believe.
Post #605401 Thu Oct 08 2020 10:31pm
Eaters
Its on the left hand side of the steering column so that makes it below the indicator stalks doesn't it? Thumbs Up
Certainly is on my 2008 Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #605402 Fri Oct 09 2020 3:53am
I think Preston-rr now has a 2014 RRS2 so opposite side of column.
Post #605403 Fri Oct 09 2020 4:40am
Eaters
Ah! OK. Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #605404 Fri Oct 09 2020 5:38am
Preston-rr
Thanks will try it out. 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #605405 Fri Oct 09 2020 6:08am
Turdmon
I’m away from home at the moment, but I think it’s the column adjustment switch? You turn it instead of using it like a joystick?
Post #605408 Fri Oct 09 2020 6:43am
Eaters
Thumbs Up Yup - 2 positions - Auto and Man Robin
Gone:
MGZTT 190 2.5
Post #605409 Fri Oct 09 2020 6:45am
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
Definitely fitted to the my 2012 (13MY) L320 too. There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #605410 Fri Oct 09 2020 6:55am
Ianc51
2014 RRS -Entry and exit mode
Does the 2014 RRS have entry and exit mode? I leave the steering column switch in auto, the wheel moves up on exit but the seat does not move. Any ideas please.
Regards
Ian Clark
Post #613779 Wed May 19 2021 10:11am
Eaters
Just a couple of guesses to try but (1) is the seat already all the way back (i.e. you're very tall)? If so it's got nowhere to go and (2) is your seat position stored in the memory as (I guess) this is what it uses to establish positions. Probably way off the mark, but maybe... Robin
Gone:
MGZTT 190 2.5
Post #613789 Wed May 19 2021 4:30pm
