Home > Technical > Bonnet catch
Ians63
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Bonnet catch
1st post.
The o/s bonnet latch on my 06 plate isn’t releasing. The n/s work fine and the handle is fully home. Suspect cable has snapped or detached from o/s latch. Any easy method to release manually?
Post #586376 Wed Sep 04 2019 9:48pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
If I remember correctly, the cable routes from the lever in the near-side foot well, through the near-side catch, terminating at the off-side catch. So I'm guessing that the cable hasn't snapped. When mine failed, it was the spring, and was easy to replace the catch. Try having someone pull the lever, while you push the bonnet down on that side slightly. It may help it to release. Thumbs Up
Post #586864 Fri Sep 13 2019 9:46am
