Home > General > My 2007 RRS |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Par for the course a lot of the jobs,, the perils of RR ownership. One job I would address straight away is the handbrake if you are having issues, if it decides to go south it could cost you in excess of a grand if you are unlucky whereas if you spend less than a £100 now and have the rear shoes cleaned and set correctly you could avoid a hefty bill. 2010 RRS, TDV8
Fri Aug 09 2019 3:40pm |
IWC1 Member Since: 15 Jul 2019 Location: Suffolk Posts: 20 |
Thanks for the advice, I appreciate it.
Mon Aug 12 2019 7:34am |
So all the work has been completed
Sun Sep 01 2019 9:38pm |
I meant to add,
Sun Sep 01 2019 9:46pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Andy - seriously no need for the switch... https://www.rrsport.co.uk/forum/topic43444.html |
Mon Sep 02 2019 6:52pm |
Ah, thanks for that, Even I can do that!
Mon Sep 02 2019 7:01pm |
w Double locking? 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Mon Sep 02 2019 8:32pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Yes familer.
Tue Sep 03 2019 2:47am |
Yes, click the remote once, 3 flashes then click once more, another 3 flashes and then the drivers door is locked. Andy |
Tue Sep 03 2019 8:52am |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
From all locked, Does all doors open with 1 press only? |
Tue Sep 03 2019 6:24pm |
No, 1 unlock just unlocks the drivers door.
Wed Sep 04 2019 2:44pm |
Maybe read the handbook - could it be this?
Wed Sep 04 2019 7:30pm |
Thanks for the suggestion, but I should have stated that I have already referred to the owners manual when I first experienced this issue.
Thu Sep 05 2019 7:18pm |
Oh, forgot to mention the good news....it passed its MOT today!
Thu Sep 05 2019 7:21pm |
