Home > General (L494) > Faulty External Temperature Readings
Angus Grizzly
Hi, has anyone had issues with external temperature readings of -40C and other very low temperatures when it is normal temperatures outside? My RRS (2016) has been doing this for a few months now and is going in for its third fix. Still not right. I have seen this issue on Disco and Evoque forums, but not RRS. The fault affects the engine management and climate control, so it is more than just a niggle. Sorry if there are loads of threads on this and I haven't found them!
Post #586012 Thu Aug 29 2019 3:23pm
wilf
Not with LR, but Jags had this issue and the cause was the temperature sensor, which was relatively cheap to replace. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #586075 Fri Aug 30 2019 8:37am
Angus Grizzly
Thanks. It is still with the dealer, so let's see. Confused
Post #586278 Tue Sep 03 2019 12:20pm
