Home > My Range Rover Sport > A few mods for Tango
knwatkins
That's really is a beautiful motor! Well done, some very tasteful mods Thumbs Up Kev
Post #582058 Sun Jun 09 2019 7:13am
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
Cheers Thumbs Up
Post #582142 Sun Jun 09 2019 10:53pm
david007
Well I thought I’d finished fitting things to Tango but I couldn’t resist one final mod, so I got a set of these today, wow I
didn’t appreciate how big they are. Discs should be here later this week then I just need to find time to fit them. Bit of a long shot but would anyone know the torque setting for the caliper bolts. Cheers.
Post #586246 Mon Sep 02 2019 6:27pm
Tyrefitter
Just make sure they are tight,Ive never used a torque reach yet on anything & I’ve never had anything fall off.while you have the callipers off I would be tempted to coat them in gtechniq C5 ceramic coating to protect them. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #586247 Mon Sep 02 2019 6:40pm
Disco_Mikey
Same torque settings as standard items Thumbs Up
275Nm for caliper bolts
Forget what the disc screws are, but barely tight is enough
Backplates are different too, so they need replacing or removing (unless they are already bigger on the facelift cars)
Post #586251 Mon Sep 02 2019 7:42pm
david007
Cheers Andy, good shout on the ceramic coating Thumbs Up
Mike your a star, thanks for the torque settings. I’m hoping I don’t need to change the backing plates, looks like they might just be big enough to take the 380mm discs.
Post #586256 Mon Sep 02 2019 8:36pm
Brit Plumber
Did you fit those sill covers? I like them and wouldn’t mind a set myself. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #586259 Mon Sep 02 2019 9:44pm
david007
Yes, got them here, the only thing I found is they do come fitted with double sided tape to hold them in place, but I had to fit a little more to get better adhesion.
https://www.ebay.co.uk/itm/RANGE-ROVER-SPO...2749.l2649
Post #586260 Mon Sep 02 2019 9:58pm
