Home > General > Battery dead again. And I’m off on my holiday!
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I was always charging my battery every couple of days if the vehicle was used or once a week if it was not. After fitting one of these battery monitors I could see that the battery was not being charged.
The car was sent to the dealers where they found the problem after a week. The main earth cable from the engine was loose. The nut holding the cable was loose and the cable was only making intermittent contact.
Post #586124 Sat Aug 31 2019 3:12am
swatkins
United Kingdom 2005 Range Rover Sport Supercharged Siberian Silver
SRE wrote:
I could leave mine in Spain for 4 or 5 weeks, but always left it in access mode. Standard JLR AGM battery.
I agree that's the key. I always park in access mode and never have a problem. Car does not self level when asleep then. Also if you open and close the car without starting the engine put key in ignition switch , rotate on and off then all the screens and computers stay off.
Post #586125 Sat Aug 31 2019 6:48am
Brit Plumber
Well I got home to find my car dead, deader than a dead thing as Baldrik would say. So it’s a good job we took HRHs car! The tedious job of finding the culprit begins. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #586128 Sat Aug 31 2019 7:52am
Brit Plumber
I’ve opened a new thread for my invest here if anyone has any comments?
https://www.rrsport.co.uk/forum/post586132.html#586132 2019 5.0 SC SVA (Current)
Post #586133 Sat Aug 31 2019 11:26am
