![]() | Home > Faults & Fixes > Handbrake fault |
Boots Member Since: 29 Jan 2017 Location: Bridgwater Posts: 10 ![]() ![]() ![]() |
Had the handbrake fixed...new cogs, hubs and pads...all working fine. Dash displays check pads and park brake fault. On the OBD the fault comes up as CA155 ignition switch.
A 56 plate 2.7 sport |
liverpool Al Member Since: 29 Aug 2019 Location: prescot Posts: 2 ![]() ![]() |
my brother is stranded in paris
Pull the cable chuffin hard, it may take 2 people but it will go. 2019 5.0 SC SVA (Current)
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
If nothing else works - Wheels and brake discs off and disengage.
cheers guys cant thank you enough
