Home > Off Topic - Other Cars > Audi A3 Overheating - Any Ideas? |
Boost Member Since: 18 Aug 2011 Location: North Lincolnshire Posts: 60 |
After some wisdom......
Thu Aug 29 2019 5:19pm |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 288 |
Did you use the correct coolant? Is it G12 spec for those? Paul Redding
Fri Aug 30 2019 7:16am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Have you checked the rad see if it’s blocked, check for cold spots if you can, could be the head gasket or even a cracked head. You don’t say if it’s using, blowing out the coolant, if not try a new temp sensor and/or check the sensor wiring had a petrol vw polo recently where the wire had rubbed thru against the block causing the gauge to go into the read 2008 G4 RRSport TDV8 current
Fri Sep 13 2019 5:26am |
