![]() | Home > Technical > High beam |
If you had definitely dipped the beams (blue light off) then I would assume the headlights are set a bit high. They can be adjusted easily enough. 2012 SDV6 - it's missing a couple of cylinders
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Thanks. Wasn't long ago had the MOT, and nothing raised there. But i'll get it checked out. 2019 RRS P400e Autobiography
Thinking back to the heady days of the early L494, I seem to remember people posting that they were being flashed a lot by oncoming cars. So maybe it's a "feature" or maybe LR just set them slightly high when fitting them. 2012 SDV6 - it's missing a couple of cylinders
