![]() | Home > Technical > Detachable towbar query |
stagfinder Member Since: 17 Dec 2015 Location: Peterborough Posts: 22 ![]() ![]() ![]() |
sorry been away for a while I have a few odd jobs for a friend collecting boat tlr's down to Christchurch to his boat yard and some of them go very heavy on the nose I only tow at an average of 120kg as a rule but the sport was rated at 250kg and I wanted to keep that for the boat trl's JLR have now issued a supplement for the book down rating to 150kg on the detach bar |
Stevieg330 Member Since: 20 Apr 2017 Location: Dorset Posts: 6 ![]() ![]() ![]() |
Hi All,
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 125 ![]() ![]() |
Steve,
RRS nutter Member Since: 10 Aug 2019 Location: Surrey Posts: 1 ![]() ![]() |
Hi M3 DPO
Wenier Member Since: 09 Apr 2019 Location: Christchurch Posts: 15 ![]() ![]() ![]() |
Love the removable towbar. In NZ the max tongue weight allowed is 350Kgs so quite a bit more than over there. Although I have done heaps of towing with it I did decide to get a security device when I was doing long trip with multiple jetskis due to the value on the trailer.
Yeah, had Advanced Factors ship one of those security plate kit's out here to me, cost almost as much to ship as to buy the kit |
Fitting it is different to the UK as we don't have the gooseneck towbar. I had a chain link between the plate and crossmember each side to space it correctly and it also meant I had somewhere to attach chains to still. Also had to cut a wee flat across the green towbar handle to get it in there.
Fortunately no problem fitting to mine, as U.K. spec. A/B which I brought with me when moved here. |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
Yeah ok I'll bite. Can't see a way for that security plate to fit with the receiver hitch. It's a very different shape to the ball hitch. 2012 SDV6 HSE (technically its hers)
As mentioned a chain link in each side to take up the gap and it gives somewhere to attach chains to.
