![]() | Home > Technical > Central locking constantly locking/unlocking when driving |
Kaywood Member Since: 01 Feb 2018 Location: Yorkshire Posts: 6 ![]() ![]() |
PS this is a Facelift 2010 RRS HSE v6 |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
I had an old Peugeot estate which had the same problem and it was a mouse in the car that had chewed wires (they like the insulation as it has fat in it). That was also intermittent and random and would also work normally as well which never helps to diagnose. Good luck
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
If it happens for the duration can you arrange to take it in when it happens and leave the car running when you get there? RRS MY17 SDV6 AB
Hi guys
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
If all the doors are locking/unlocking together, intermittently, start by investigating items that are designed to do this. i.e. check the wiring to the global lock and unlock switch (on the drivers door on a facelift?) Will likely mean removing the drivers door card and checking for good wiring, no water ingress etc near to the switches. Also investigate where the cables run through the rubber conduit where the door is hinged.
bellcrank Member Since: 19 Jan 2015 Location: Kent Posts: 11 ![]() ![]() ![]() |
Kaywood, did you ever solve your central locking issue? I have had the exact same intermittent problem for over a month now in my 2011 HSE. So far I have replaced drivers door latch and had Land Rover diagnosis which didn't turn up anything. It's driving me mad, just off to my shrink for some therapy.... |
Any other problems to go with it? Wet passenger front carpet? Radio playing up? Indicators a bit random at times?
No other problems at all Brit Plumber. The only thing that has happened during all this is that the rear passenger door lock stopped working which I've replaced and I think is coincidental.
So it doesn’t do it with the auto lock option off in the menu in the cluster? Sounds like a CAN bus fault. The auto lock feature happens at something like 5mph so it’s the trigger signal but that could be something to do with the new actuator you fitted. Was it the same part number and has it only happened since fitting the new part? 2019 5.0 SC SVA (Current)
It does it with auto lock on or off. I had the new drivers door latch fitted as a potential solution suggested by a friend who is a Land Rover technician. That didn't work. The rear passenger latch was replaced last week as it refused to unlock but this I believe is just coincidence.
