CornishRob
![](templates/vbnew/images/spacer.gif)
I guess you may have fixed this now, but thought I would reply, so it's on-the-record, as it were.
Usually it's the condenser that fails, so the usual procedure is to get it re-gassed with the dye added, and look for leaks with UV light. However, the leak can take a while to show itself, ie unless you have a big leak, it takes a few days for the dye to stain the hole sufficiently so you can spot it.
So don't worry if they re-gas it, then can't find a leak. Drive around for a week, then take it back, and the leak will be quite obvious. ![Thumbs Up Thumbs Up](images/smiles/icon_thumbs.gif)
Sun Aug 25 2019 9:03am |
CornishRob
Quote:Buuuut, it is illegal to regas a car knowing there is a leak in the AC system...
The CORRECT procedure is to pressurise the system with Nitrogen, and use either soapy bubbles or a sniffer to detect any leaks, repair as req, retest with Nitrogen, and if all is OK, then regas Thumbs Up
In addition, most of the R1234 machines do not have an allowance for adding dye to the system
Fair enough, I didn't know this, I was just relating what happened to me when I had mine fixed this year, and that it took a while for the leak to become evident.
Sun Aug 25 2019 4:46pm |
