Home > Maintenance & Modifications > Rear Brake Caliper Piston
GerryG
Scotland
Hey
I need to change the front and rear discs and pads 2008 RRSport TDV8 ( pads not worn ) discs are goosed, the rear piston wont retract, is there a way to get this back in or do I need a wind in tool, car has the EPB
Appreciate any help
Gerry
Post #585776 Sat Aug 24 2019 10:59am
gogsy1956
Proper tool makes life a lot easier,, unless you have a large "G" clamp handy. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #585778 Sat Aug 24 2019 1:01pm
Brit Plumber
The EPB works on shoes inside the drum part of the brake so no special wind back tool required. I just use a big G clamp. Have you popped the reservoir cap off to make sure you haven’t got to much fluid, especially if you’ve already sorted the fronts. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #585781 Sat Aug 24 2019 1:53pm
The year of your car is an important questuon
Post #585790 Sat Aug 24 2019 6:15pm
Brit Plumber
It’s a 2008 car according to his post. 2019 5.0 SC SVA (Current)
Post #585791 Sat Aug 24 2019 6:27pm
You shouldn’t need a wind back tool.
It’s a sign the piston is siezed. Which is common.
New caliper time. Not expensive.
Post #585802 Sat Aug 24 2019 9:24pm
GerryG
Scotland
Got it with G Clamp, sure took some force though, other side ( pass ) is proper seixed, guy used it to tow a boat, reversing in water ) dont know whether to change the caliper or rebiild it
Post #585812 Sun Aug 25 2019 12:19pm
GerryG
Scotland
Thanks mate, used a G Clamp
Gerry
Post #585813 Sun Aug 25 2019 12:19pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Are these calipers non serviceable? 20+ years ago I used to remove the pads, carefully push pistons out a little further then clean corrosion to check no pitting then push back in. If the pistons were pitted then new ones could be bought.
I've never worked on newer car calipers though.
Edit:. Just read on another post, it's not worth repairing due to costs of complete caliper. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #585821 Sun Aug 25 2019 1:10pm
Brit Plumber
When I did mine last month, I popped a piece of wood in the Caliper and pushed the piston out on the foot pedal. Obviously you have to be careful how far you pump it out or else you will pop it out of the caliper and it will need refitting and the system bleeding. Once I had it out as far as I dare, I washed the the rubber boots with mild washing up liquid and covered it in tyre dressing and let that dry in. I then put rubber grease on and removed the remaining residue until it was near dry. I then pulled back the boot out of the piston groove and gave that a clean. There was some corrosion evident in the exposed areas but the booted areas were clean. I did scrape some deposits out of the piston groove and lubed with red rubber grease to help the boot seal and to protect the groove from more corrosion. 2019 5.0 SC SVA (Current)
Post #585824 Sun Aug 25 2019 1:25pm
Yeah it's not worth rebuilding.
I put a new piston in mine, but it didn't fix it!
Turns out there is a groove that needs cleaning out, which causes it to seize. So if you know what you are doing, clean out the groove behind the seal.
But you may as well fit new ones
Post #585829 Sun Aug 25 2019 4:48pm
