![]() | Home > Technical > Rear Door Won’t Open |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
I had this problem, but I managed to open it, by getting someone to press the unlock button on the dash, and pull the internal door unlock lever at the same time. After one or two goes, it unlocked.
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
Cheers for the reply, I have tried pressing the unlock button (both on dash and keyfob) whilst trying all the levers but no joy. I’ve also got the replacement actuator unit and from looking at that it appears it should open when the cable levers are activated. The cables are now disconnected (after a lot of fumbling around in the door skin) but I can feel and physically move the levers, but the lock remains closed? |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
Have you tried the combination: hold down both lock & unlock on dash whilst another person activate levers?
Still no joy.........activating the release levers (mechanically) on the lock mechanism does not release the lock. I'm thinking that the door might be 'superlocked' meaning both mechanical levers are disconnected internally. I believe all of the locks 'superlock' when you lock with the key fob, meaning they can't be opened from inside or out (preventing theft). The problem is, if the actuator develops a fault whilst in this state I can't see how you'd get it open, other than brute force. I could try and apply 12v directly to the superlock motor to see if that helps release it, anyone know which wires i'd need to apply to? |
you may have tried this many times but from outside pressing unlock on remote repeatably and simultaneously pulling releasing door handle many times over.
Hopefully you have fixed this now, but if you haven't, do you have the child locks engaged on the rear doors? |
Big thanks to all who posted and helped me out with this one. Hope this might help others in the future. Basically, I think I was on the right track with the 'Superlock' idea. After digging in a bit more it seems that the car can be configured to 'Superlock', which means neither internal nor external handles will open the door. This is to prevent someone smashing the window then opening from the inside. Additionally the dash unlock button will not open the car when 'Superlocked'. It seems that the function is standard with one press of the lock button on the remote with UK spec cars, though could be programmed differently. If you sit in your car and lock it with the remote, you'll find you cannot open any doors if Superlocked. So, the only way to open the car was with the remote, so I now stopped trying the dash button and focused on the remote. I then gave the actuator a few taps with a block of wood and a hammer hoping this would free things up if they were jammed. Next I got the Mrs to unlock with the remote whilst I activated the external door handle lever, and to my delight the door opened! Happy Days! I'm going to have a look when I get time but I believe inside the actuator are two motors and several gears. One of the motors is for the Superlock. I think I had a problem with this or the gearing. Incidentally, the child lock was on (I couldn't remember) so the internal lever would have never opened the door. |
