![]() | Home > Technical > Rattle / clonk from rear |
I think I tied pipe insulation to the dampers. To stop this.
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
(Just in case anyone else has this), it's definitely the harmonic dampers (two big metal weights under the rear body, between the spare wheel and the bumper. I think it must be that the rubber bushes that they hang on have aged, and allow too much movement, so they hit either the bumper or a metal bracket on the underside of the boot floor.
Stopping the harmonic dampers swinging about so much has had a strange effect on the RRS. It seems much nicer to drive, with a noticeable reduction in vibrations from the rear when driving over rough surfaces, potholes etc. |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
I think I've heard an occasional clonk from the back .. must crawl under there and have a look for these, what I now imagine to look like, Range Rover Testicles.. |
