![]() | Home > General > Battery dead again. And I’m off on my holiday! |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
I know I'm comparing apples to oranges, but that's exactly what my BMW was doing, even after I changed the battery .. right up until I did the "battery registration" dance in the diagnostics. I didn't believe it could make a difference but .. now it can sit for 2-3 weeks without use and still fire up first time on the button.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Cheap solar panel off of Ebay?
I keep one of those small jump starters in the boot tool tray now for situations such as this. It saves carrying around a set of jump leads and you don't need to flag down another car when you're stuck. If your battery is flat when you return, just open manually, pop the jump starter on and fire her up.
Thanks chaps, I’ve been looking at the small power packs which look very handy but no one can get me one until I’ve left lol. 2019 5.0 SC SVA (Current)
I have one of those VHS-sized jump packs, too; very handy and started an absolutely flat Hummer H2 at Le Mans a couple of years ago! If you are driving past here, you're welcome to borrow it for the duration. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 125 ![]() ![]() |
Do you recommend yours please? |
Yes. To test it, I drained my battery down (bad for the battery, I know) and it started the TDV6 with no problem.
Wd40 you key barrel
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
Use Graphite Powder Lock Lubricant instead IMO |
Problem solved. Taking the wife’s car and leaving mine on the trickle charger.
Good choice |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 251 ![]() ![]() |
Living approx 70 - 80 miles from both Gatwick and Heathrow, we always take a taxi (a trustworthy one man band private hire airport specialist). Costs approx £90 each way which may be more than the parking costs but by the time we include petrol we reckon it is worth it as the holiday starts when we lock the front door and end when we unlock it a week or two later, we know the cars are safer at home and with the Brucie bonus of no drink drive worries on the plane home. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
I could leave mine in Spain for 4 or 5 weeks, but always left it in access mode. Standard JLR AGM battery. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
