Home > Maintenance & Modifications > Roof rails |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Any good. The description is wrong though the rails are handed, the numbers they are quoteing are actualy for the plastic end cap/pieces which are avaliable seperate as a kit off 4 two front's and two rear's.
Mon Aug 19 2019 8:22am |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
Thanks, Col. Just the job. How did you find those when I couldn't? |
Mon Aug 19 2019 9:05am |
Because I'm a sad sod with to much time on my hands.
Mon Aug 19 2019 9:08am |
In that case, what fittings do I need? |
Mon Aug 19 2019 11:33am |
Don't need much, unfortunately none of it available separate from L/R. If you are lucky they may have saved them when removing the rails, although the plastic grommets generaly break when trying to remove them.
Mon Aug 19 2019 10:08pm |
Thanks, Col. Nothing too exotic that a trip to the local fixings shop and some imagination won't fix. |
Tue Aug 20 2019 5:41am |
I'm surprised the car doesn't need an expensive software from LR to 'enable' the roof rails. |
Tue Aug 20 2019 7:40am |
Oh no, you’ve just given them an idea.... 2019 5.0 SC SVA (Current)
Wed Aug 21 2019 7:54pm |
