Home > Technical > Wet carpets
briggsy597
United Kingdom 2006 Range Rover Sport Supercharged Sumatra Black
Wet carpets
Hi, I have a 2006 Range Rover sport. It’s had a very wet carpet in the drivers footwell, I checked the sunroof and it wasn’t a great seal around the glass and also checked the 4 x drains and they seemed ok. I sealed up the sunroof with insulation tape to prevent any further leaks, but unfortunately a few days later the carpet is wet again !!! I’m sure it can’t be the sunroof, any other areas prone to leaks ?
Thanks
Post #585479 Sat Aug 17 2019 6:30pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Look in the general section and watch the water leak video.. Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #585482 Sat Aug 17 2019 7:41pm
briggsy597
That’s a great vid !!!! Thank you
Post #585486 Sat Aug 17 2019 8:04pm
