![]() | Home > Maintenance & Modifications > Fitting side steps |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
Swapped mine out a while ago , for the same reason as you
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 ![]() ![]() ![]() |
did the exact same also. Car set to full height, impact gun zipped the old bolts off. Cleaned up the brackets and fitted the new ones. Spray some WD40 or washing up liquid along the edge of the new runners when putting them on, to just help slide them into place. |
Keep the originals as the guage of steel used is thicker 2019 5.0 SC SVA (Current)
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Thanks for that guys, seems like a plan |
Mine came from here: https://turborevs.org.uk/side-steps-runnin...sport.html
Those were the ones I was looking at Kev. I take your point about protecting the underside. |
