![]() | Home > General > suspension compressor pipes |
triplemmm Member Since: 22 Mar 2014 Location: SE Posts: 78 ![]() ![]() ![]() |
Hi
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4452 ![]() ![]() ![]() |
Britpart do a pipe repair kit |
Thanks Mikey - Do you mean this? https://www.britpart.com/parts/repair-and-...ors/da3964 |
Thanks Gogsy that makes sense. - So these? https://www.ebay.co.uk/itm/Nylon-Air-Line-...2674688783 I then have to get bits to go into the two pipe ends as well? |
Yes, providing you have a Hitachi compressor fitted Different kit for the AMK ![]() |
Cheers Mikey. yep Hitachi.
I had to do the same on my compressor - these are just low pressure pipes - one is air intake and the other air exhaust.
No pipe inserts required for the push fit connectors,, just cut the pipes with a junior hacksaw so the pipes stay in shape 2010 RRS, TDV8
Thanks Garry and Gogsy!
